This custom Lord of the Rings themed lamp is a dual morph polyhedral that is 50% in between a pentagonal hexecontahedron and a snub dodecahedron. I used Stella4D to project a customized map of Middle Earth onto the faces and UV printed the map using the Eufymake E1. The frame parts were designed in Fusion 360 and 3D printed on a Bambu X1-C and H2S.
3d print time: 53.81 Hours using 920g of filament Uv print time: 2.97 hours on 5 sheets of clear acrylic using 5.59ml of ink. Laser time: ~67.5 minutes, 10 prints on 5 sheets using snapmarks.
The bed size of the eufymake and the glowforge are slightly different, but the easiest way for me to print these was to create a custom printer preset for export out of stella4d, export as PDF, then create multiple layers in Illustrator to import multiple graphic layers with snapmarks into Eufy studio, and a separate SVG for the cut lines and snapmarks for the Glowforge. I could have used photoshop to isolate each individual face graphic, and then organize better in illustrator to eliminate wasted material, but I was okay with saving that time. The height of each graphic is more than the Glowforge cut area, so I just used the snapmarks to align and cut the top half first, and then repositioned, realigned, and cut the bottom half. 5 sheets, 10 print jobs. I do have print and cut on my Mira 9 with lightburn, but I’m comfortable with using snapmarks when they work. Might as well get something out of that premium subscription.
Not only am I a big fan of the trilogy, but also pineapple on pizza!
How do you sleep at night with all that designing going on in your brain? That is so far above my pay grade that it makes my brain hurt thinking about your design steps! This is truly a masterpiece! I’m so happy you share all of your creations with us.
