If you are using the living hinge extension/plugin for Inkscape you may want to use this version instead.
It optimises the cut order to minimise head movement. It saves between 10% and 20% of cut time!
Find your existing copy of kmlaser_living_hinge.py - which is usually in C:\Program Files\Inkscape\share\extensions and open in notepad and replace it with this:
#! /usr/bin/env python
hinge_cuts.py
A module for creating lines to laser cut living hinges
Copyright (C) 2013 Mark Endicott; drphonon@gmail.com
Modified 2018 Simon Q. Walden sqw@c2000.com
SQW mods make lines run in opposite directions for optimised head movement.
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
For a copy of the GNU General Public License
write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
Change in version 0.2.
Changed inkex.unittouu to self.unittouu
and inkex.uutounit to self.uutounit
to make it work with Inkscape 0.91
Thanks to Pete Prodoehl for pointing this out.
__version__ = "0.2"
import sys,inkex,simplestyle,gettext
_ = gettext.gettext
def drawS(parent, XYstring): # Draw lines from a list
name='part'
style = { 'stroke': '#FF0000', 'fill': 'none', 'stroke-width': self.unittouu("0.1 mm") }
drw = {'style':simplestyle.formatStyle(style),inkex.addNS('label','inkscape'):name,'d':XYstring}
inkex.etree.SubElement(parent, inkex.addNS('path','svg'), drw )
return
class HingeCuts(inkex.Effect):
def __init__(self):
# Call the base class constructor.
inkex.Effect.__init__(self)
# Define options - Must match to the <param> elements in the .inx file
self.OptionParser.add_option('--unit',action='store',type='string', dest='unit',default='mm',help='units of measurement')
self.OptionParser.add_option('--cut_length',action='store',type='float', dest='cut_length',default=0,help='length of the cuts for the hinge.')
self.OptionParser.add_option('--gap_length',action='store',type='float', dest='gap_length',default=0,help='separation distance between successive hinge cuts.')
self.OptionParser.add_option('--sep_distance',action='store',type='float', dest='sep_distance',default=0,help='distance between successive lines of hinge cuts.')
def effect(self):
unit=self.options.unit
# starting cut length. Will be adjusted for get an integer number of cuts in the y-direction.
l = self.unittouu(str(self.options.cut_length) + unit)
# cut separation in the y-direction
d = self.unittouu(str(self.options.gap_length) + unit)
# starting separation between lines of cuts in the x-direction. Will be adjusted to get an integer
# number of cut lines in the x-direction.
dd = self.unittouu(str(self.options.sep_distance) + unit)
# get selected nodes
if self.selected:
# put lines on the current layer
parent = self.current_layer
for id, node in self.selected.iteritems():
# inkex.debug("id:" + id)
# for key in node.attrib.keys():
# inkex.debug(key + ": " + node.get(key))
x = float(node.get("x"))
dx = float(node.get("width"))
y = float(node.get("y"))
dy = float(node.get("height"))
# calculate the cut lines for the hinge
lines, l_actual, d_actual, dd_actual = self.calcCutLines(x, y, dx, dy, l, d, dd)
# all the lines are one path. Prepare the string that describes the path.
s = ''
for line in lines:
s = s + "M %s, %s L %s, %s " % (line['x1'], line['y1'], line['x2'], line['y2'])
# add the path to the document
style = { 'stroke': '#000066', 'fill': 'none', 'stroke-width': self.unittouu("0.1 mm")}
drw = {'style':simplestyle.formatStyle(style), 'd': s}
hinge = inkex.etree.SubElement(parent, inkex.addNS('path', 'svg'), drw)
# add a description element to hold the parameters used to create the cut lines
desc = inkex.etree.SubElement(hinge, inkex.addNS('desc', 'svg'))
desc.text = "Hinge cut parameters: actual(requested)\n" \
"cut length: %.2f %s (%.2f %s)\n" \
"gap length: %.2f %s (%.2f %s)\n" \
"separation distance: %.2f %s (%.2f %s)" % (self.uutounit(l_actual, unit), unit, self.uutounit(l, unit), unit,
self.uutounit(d_actual, unit), unit, self.uutounit(d, unit), unit,
self.uutounit(dd_actual, unit), unit, self.uutounit(dd, unit), unit)
else:
inkex.debug("No rectangle(s) have been selected.")
def calcCutLines(self, x, y, dx, dy, l, d, dd):
Return a list of cut lines as dicts. Each dict contains the end points for one cut line.
[{x1, y1, x2, y2}, ... ]
Parameters
x, y: the coordinates of the lower left corner of the bounding rect
dx, dy: width and height of the bounding rect
l: the nominal length of a cut line
d: the separation between cut lines in the y-direction
dd: the nominal separation between cut lines in the x-direction
l will be adjusted so that there is an integral number of cuts in the y-direction.
dd will be adjusted so that there is an integral number of cuts in the x-direction.
ret = []
# use l as a starting guess. Adjust it so that we get an integer number of cuts in the y-direction
# First compute the number of cuts in the y-direction using l. This will not in general be an integer.
p = (dy-d)/(d+l)
#round p to the nearest integer
p = round(p)
#compute the new l that will result in p cuts in the y-direction.
l = (dy-d)/p - d
# use dd as a starting guess. Adjust it so that we get an even integer number of cut lines in the x-direction.
p = dx/dd
p = round(p)
if p % 2 == 1:
p = p + 1
dd = dx/p
# Column A cuts
direction = 1
currx = 0
donex = False
while not donex:
doney = False
starty = 0
endy = (l + d)/2.0
while not doney:
if endy >= dy:
endy = dy
# Add the end points of the line
if direction == 1:
ret.append({'x1' : x + currx, 'y1' : y + starty, 'x2': x + currx, 'y2': y + endy})
else:
ret.append({'x1' : x + currx, 'y1' : y + endy, 'x2': x + currx, 'y2': y + starty})
starty = endy + d
endy = starty + l
if starty >= dy:
doney = True
# flip direction
direction = 1 - direction
currx = currx + dd * 2.0
if currx - dx > dd:
donex = True
# inkex.debug("lastx: " + str(lastx) + "; currx: " + str(currx))
#Column B cuts
direction = 1
currx = dd
donex = False
while not donex:
doney = False
starty = d
endy = starty + l
while not doney:
if endy >= dy:
endy = dy
# create a line
if direction == 1:
else:
starty = endy + d
endy = starty + l
if starty >= dy:
doney = True
# flip direction
currx = currx + dd*2.0
if currx > dx:
donex = True
return (ret, l, d, dd)
# Create effect instance and apply it.
effect = HingeCuts()
effect.affect()
