Drove by this mill one day and wandered if I could cut this on the Glowforce. So the next day I came back with my camera and shot pictures of all angles and started to draw and make this mill.
It’s been made 99.8 % on de Glowforce except for the obvious things like axes and used needle file set and sand paper a few times.
The mill was rebuild in 1783 after the original mill was burned down. It’s unknown when exactly the original was build.
To make this I used:
My drawings
(To make the curved wings drawings a friend helped.
Amazing piece! Is the other still in use? I have always wondered how they set the cloth sails to variably cover the different arms to match the current wind.
That is a wonderful representation of the mill. I loved the photos of the actual building, and I would really like to see it on a nice day when the ducks are enjoying the water.
Yes the mill stands in the middle of my home town. It use to be grassland for miles. Now they made a pond around it and a little park. But it still turns from time to time.
If you have the drawings you can easily build it in a week But to glue the roof and base is glued layer after layer so it takes some time to glue it together. To get the curves in de wings means that every joint has a different angle and are all separate parts so it takes at least a day to glue together.
But I started to draw in may 2021 and change parts because I didn’t like the proportions and been in and out of the hospital this year. So you can do it in a few weeks but I would take your time for it
Thank you all for the nice reply’s
I didn’t design it by the way I am not that old
You had a lot of clever people in the 1500 and 1600
We still have dry feet, even if we are 7 meters below sea level!
