What’s the best kind of paint to use for wood that didn’t leave streaks
It will depend on what your wood is and how it is prepared. Can you provide any detail?
Are you asking about streaks in color were the coat isn’t opaque or streaks in the finish even after you get good coverage?
Heirloom paint is wonderful.
if you are getting streaks under your masking after using spray paint, it is most likely wicking through the wood grain. If that is the type of streak you are getting, try hitting the piece with a coat or two of clear and let it dry before coming back with your color.
