printing problem.zip (929.4 KB)
Can anyone tell me why the planet in the logo won’t print? This is an illustrator file. Thank you in advance!
Try this instead
GF cannot process AI files. You need to convert to SVG. Also, I deletes the white background from the planet
It is still showing as an image trace.
Select it, Expand, Release, Minus Front and you’ll have a compound path with a fill. It should work fine from there.
I chose a PG material just to illustrate:
Have fun!
I am always truly impressed by the community every day. Thank you @gmckayca and @hansepe! That is exactly what is going on here.
@jonnyvermont did that help you get the results you were looking for?
That’s it! Silly me! Thank you community!
