The passthrough program is not working properly. After thr first cut does not take pics. Just states fail to print. When you select align manually it gives you an error message and the only option that it will allow is cancel print. I use the pass through softwear regularly.
In case you haven’t seen it, there is apparently an ongoing incident that they’re working on:
Thanks, I had not seen that.
I’m sorry about the trouble when using Pro Passthrough. Thank you for reporting this and bringing it to our team’s attention. We’ll continue to investigate, and the status page will be updated once there is more information.
