I made this for my own use to hold and protects tablets so is a bit worse for wear but was done the way I outlined, That plywood looks terrible engraved so this was all scores.
How the heck did you score all of that fill?
Just as I laid out. It was a jpeg and not PNG but did not exist for an hour as it was directly put to trace after being made. It was created by making one leaf then arranged in a group and that made into a pattern
Huh!
the actual group was the four vertical and horizontal leaves and then the 45 degree leaves added to the 90 degree angles so as a pattern the unconnected leaves connected at the corners
I’m sorry that you hit a snag when uploading your design. It’s great to see that you received excellent advice from other community members and that it got you up and printing! Thank you @jules and @rbtdanforth!
I’m going to go ahead and close this thread. If you run into trouble again uploading designs, please reach out either on the forum or by emailing support@glowforge.com and we’ll be happy to help.
