When you finish a print, unless a proofgrade material is called out the focus goes back to default and the image on the screen appears to move, As noted if you have cut away the place that the focus was will be lower. For this reason I generally try to use the set focus off to the side of the engrave where it can be repeated if necessary. When you do that the focus point may move some (especially if the material is thick) and so I may use the set focus several times till it is in the correct location. only then will the image line up. If you are working without the crumb tray I would tape the piece to the bottom so it cannot move in case you want to make a different pass.
If you open the lid rather than just run it again then it will need to re focus. If you haven’t opened the lid it should follow the exact design over again.
