Pdf file
I purchased an etsy file and owner says to use the pdf file as GF will sometimes resize the svg. I’m fine with that but her pdf file is grouped with 2 items. I need them ungrouped because I am using separate colors for this file. the ungroup option is not working in gf on this file. Is there someway to ungroup a pdf file?
You can try opening the svg file and see if it will allow you to ungroup, or you can export the file and open it in something like Inkscape to see if you can ungroup it, or you could ask the file seller to ungroup it for you.
Or if you know what size is supposed to be, use the .svg and if it adjusts use the ruler in the bottom left to fix it.
Have you tried double clicking into that group to get to individual elements?
