@deirdrebeth Thanks. It was my first foray into using the resin. I didn’t tint it dark enough, so when it set it was pretty light. I went back over each area with a colored sharpie. Also I have to plan better for the frame. Part of the frame is blocking the edges of the clouds on the sides. Practice make perfect, I suppose.
@cynd11 Thank you. I like to tinker with projects that go quickly, so the GF lends itself well to this. My wife and I have been having a blast with it.
@ryan.niemer Thanks! I pulled a map off of the net and converted it in Inkscape. It took longer to get it laser ready than I had thought it would. Of course, I’m relatively new to using Inkscape. And apparently I used a good map, because my Stepfather said that Elswere was relatively new. I ended up leaving some of the smaller islands out due to the scale of map I was making. He didn’t seem to mind.
