Made this from a free design I found randomly. There were several issues with the original design that I had to fix first, bit it came out pretty well…at first.
Yes, that is 30" wide, so i had to split the design into 3 pieces.
But this is a cautionary tale about using cheap material. Below, This is typical of the cheap stuff i bought from Home Depot. This is the back side. Notice how I had to bust out the cuts in 2 particular straight lines. It’s where the glue is a bit thicker and so the laser doesn’t cut through. The solution would be 2 passes, but on 2nd pass you scorch the front a bit, so you have to mask it. But that’s better than ruining an 11"x30" cut
This will work fine for Halloween though.
