Has anyone made an above ground pool tray. sits on the side of the pool i do not know how to design.
Easier to think through what you have in mind than have others design it differently. I can think of a hundred ways that most will not be what you are considering. Floating on foam that goes where you go would be my first thought. Thinking of a foam drink holder while floating down a river as an ultimate something.
It is to hang on the side of an above ground pool
This will get the details for you. Just make an open box with the sides longer than indicated to make hooks the size you need,
https://www.festi.info/boxes.py/
To have a post here you need to post your design for others, not ask others to invent their’s. Since you are not doing that this post needs to move to "Everything Else"and I can do so for you,
Ok thank you
Ok thank you
Box-O-Matic is a free app to design all types of boxes and trays. Very EASY to use.
