My exterior wall has shingles, and the placement of the doorbell wire makes it difficult to mount a fancy doorbell, larger than a simple button. Glowforge to the rescue!
(happy to share the cut file, but it doesn’t seem relevant to anyone else)
Material used is Ruisita Unfinished Square Wood Pieces. I specifically did not use PG here, because I did not want the veneer layer, and cheap wood would suffice.
I made something very similar to mount a Next doorbell for a friend. I didn’t take pics or save the file. It came with a plastic bracket but that didn’t fit the angle of the siding perfectly where the wiring was, just needed to be shimmed a little.
My GF is just another tool in my workshop for solving problems like that.
I need to design something that will be similar to this but also has some type of theft deterrent. But I don’t want it on the front door (like this example below) since we often have the door open. We have a screendoor that is kept closed, so I don’t know. We will see. I haven’t worked on it yet at all.
