My precision Power is no longer working correctly. Its now cutting the same as full power with a much wider dispersion rate , Any ideas as to how to fix this ?
Can you share a photo of the wider cut and elaborate on whether or not you used saved settings, input settings or used Proofgrade settings?
Any possibility you have the lens in upside down?
I did check that, the problem is the very fist pass is perfect but the next 2 passes are way off causing the wide cutting and for it not to cut. Thank you Rober.
I’m sorry for the ongoing trouble. I see that we have a support ticket open with you via email, and we’re continuing to assist you on this topic there, so I’m going to close this thread and we’ll be in touch with you again soon via email.
