Starting this morning the preparing to print dialogue is just sitting there spinning, I’m at 15 min now and eventually it just errors out and says print failed and refresh the browser. This is for a file i have already cut many times in the past. As a test I loaded a single simple image and it eventually did load but even it took a prolonged amount of time.
This generally happens when there is a problem with the file. If a different file processes without issue, then it is definitely the file which needs to be addressed.
