Print and screen not agreeing!
Running a GF Pro… what I see on the computer and what prints are not mirror images. The screen shows text centered on the object, the actual print has text moved slightly!!
Welcome to the forum.
The view you get on your computer is from a fish eye lens in the lid of the Glowforge adjusted via software. Always use the set focus tool prior to placing your artwork, and make sure that the red beam lands squarely on the material at a point you intend to use for your design. You will get the best results directly under the camera. The Glowforge specs warrant the camera to be accurate to within 1/4". Most of us get much better results than that, but if you must have precise placement you will need a jig and/or use the placement tools.
Thank you for the response… will try your suggestions.
