When the unit is first turned on, the print head moves from the upper left to the center, then to the right center, then back to the upper left corner like usual. When I start the print, print head will move to the auto focus point and the red light comes on, the print head moves slightly then the red light comes on again, then the print button lights up, GF interface says it’s ready to print, without the print head returning to the upper left corner. If I hit the print button, the print head will move as if it is starting in the upper left corner, which of course will not be correct if the focus point is anywhere else on the cutting material.
I have turned off the unit and manually moved the print head back to the upper left, I have restarted my browser, I have moved the print head directly under the camera and turned the unit back on, all with no effect. Any ideas?
