The new lights are awesome!
How long does it take to chill before starting to print - is it only until itās within operating range?
Would it be possible to have a setting that lets you āprechill before starting to printā that cools to the lowest temperature before the job starts? (I.e. I would accept a slower start if the coolant was cold enough to run the longest at the beginning, rather than only chilled enough to pause 3 minutes later)
I donāt understand how it can do any cooling at the start when the machine has been sitting and everything is at ambient temperature. Unless it has been run recently, and has some residual heat, there is nothing it can do by blowing ambient air over a system that is already at ambient temperature.
It always amuses me to hear people say they turned on a fan and then left the room a while to let it cool down.
Perfect. Thanks @dan
EDIT: for additional response,
He also said
So they have adjusted that and that should help.
However the big answer to your question is the exhaust port. It has already been shown that the outside heat/cold/humidity can enter the machine through the exhaust port when the machine is dormant. Running the fans at the beginning will evacuate the stale air and allow the coolant to get a good cycle through the heat exchanger. Iād say itās a solid idea that defiantly couldnāt hurt to have if it is 95Ā° outside and 74Ā° in the room.
Iām probably in the minority, but I actually prefer the bright lights when the lid is opened. The bed is still brightly lit which makes it easier to align the material as straight as possible. This is one of the settings that would be cool to have listed under Preferences (along with other things like āRun fan x seconds after print finishesā). With all of that said, this is a minor issue and Iāll be happy either way.
