I have gone through the procedures to get the glow
forge online and it will not work.
I may not be much help but are you using a 2.4ghz connection? If so have you tried using your phone as a hot spot?
Leave as much info as you can so someone can perhaps offer some clue as to what went wrong.
I tried my Verison Hot spot and the WiFI with Media Com. Everything indicates it is connected until I try to print, then is says I am offline.
I recall something similar that I got the glowforge connected but had to get the laptop back connected to the wifi instead of trying to connect directly to the glowforge.
So you’re successfully connecting the to where it says “Online”, but then when you hit Print it goes offline? Or something else?
My AppleTV was causing a similar issue. If you have one either disconnect or move your GF to a dedicated 2.4 channel on your network.
Any update?
Update.
I have two glowforge machines and the wrong login email was posted so it would not go online. I put in the correct email and things are working fine.
Good to hear it was a simple fix. Happy forging!
