Printer not listed for calibration
Iam trying to calibrate my glowfore pro but it is saying my printer is not listed. No printer is listed to select.
Welcome to the forum.
Support will get back to you and be able to help. While waiting for that reply, I suggest using a different browser to open the app.
I just tryed a different browser, same issue. Thank you for your reply
If you check your network do you see your glowforge connected? If something in your network changed recently that may be a problem
Thank you for your suggestion. I did see my glowforge in my network and it went through the process and said it was connected. I tryed redoing the camera cal again and my printer is still not showing up.
While waiting for Support to help you with this, I suggest you print a few projects so you get an idea of your current alignment situation. Sometimes the lid camera calibration is not even necessary.
Hello @carrie5
Since we are now in contact about this trouble by email, I’m going to go ahead and close out this forum thread.
