I need to find a way of producing the effect of sequins sewn onto silk fabric, the shapes of the sequins and the pattern they make to be designed by me.
Not difficult, I’m sure you’ll agree.
I can see that the simplest method is to use the foils that are used for transfering metallic effects onto T-shirts and such like, but from what I can see, the weave of the fabric always shows through, as the foil is so thin.
Does anyone know of a thick foil that might retain the flat ‘mirror-like’ surface, preferably not a vinyl !
An alternative idea that I might explore is to press the whole sheet of foil, first onto a thin paper sheet, spray that with a heat setting adhesive (shellac ?), then laser cut, weed, then finally hot press.
If anyone has dome something like this, or has a workable idea that will steer me in a new direction, I’d be most grateful to hear.
I have considered inventing a sequin-gun, something like a modified glue gun, where the glue is squashed to form a firm base for the foil, or gold leaf, but with about 1000 sequins on the design, with 4 different sequin shapes, the time involved becomes uneconomic.
I’ve got about two months to solve the problem, but lots of other things to do in the meantime, so I need to push this onwards.
John
Now that 2017 has come out you should be able to get a copy of X8 - they did some nice improvements to trace and similar functions in that version. 2017 is a $200 upgrade and I’m not seeing anything I need there to force me to upgrade
