Hi all, I read through a number of posts hoping to find an answer but didn’t have much luck. We cleaned the fans last night (both the main and air assist fans) and when I ran a test print using my most reliable cut it went horribly wrong. The print at the bottom should look like the one above it:
I checked the belts and they seem to be tight enough, maybe a tad looser than I’d like on the carriage plate belt, but the right hand wheel is all the way over to the right. My only thought is whether the left side can be adjusted too?
I tried camera recalibration which is also wonky:
And the precision focus which is actually on par, although the engraving is still distorted:
I’m hoping someone knows what I’ve done wrong and can help me out with this!
