I have used the pass through for a variety of things and am running into an issue. The first item I cut was an 18 inch circle and it worked perfectly fine with a 20 inch board. The second time cutting an item (outline of a Star Wars Falcon) is 20" long so will take 3 passes. The first pass it will cut fine and I do a realignment. When I pull the item forward as directed and hit continue the right side for some reason jams as if it is caught on something and then the second print is off. I cleaned the machine, made sure no bits are on the belt etc and retried it. Same exact thing. I went back and printed it so it was only two prints and no issues. It makes a grinding sound when the belt or side on the right side catches. Any suggestions?
The machine is only a month old too BTW.
