Problem in Inkscape SVG engraving
It’s there. Check out this post to tag SVGs to increase their display size.
You have a lot of open paths in this design. I assume you want those paths/strokes to be a wider engrave as an outline. Vector lines only score and cut. If you make them engrave, they are going to have funky straight edges to connect the ends of the lines, much like if you tried to fill those paths.
Did you want to the text to engrave as a fill?
You might want to save the angel and text as a bitmap and place that within the line of your cutout profile.
Check out this nightlight I did to see how the design can be all vectors but engraved as outlines
Nightlight
