Yesterday for many hours I could not connect my new GF.
I discovered my iPad is on 5 GHz. I have an Apple AirPort Router. Using the AirPort Utility app on the iPad there is not a way to change the iPad for 2.4 GHz.
I got my MacBook Pro out to check my wi-fi. It was also set at 5 GHz.
Did some research to learn how to change it to 2.4 GHz.
I now have two networks one on 2.4 and the other one running on 5.
I then used the MacBook and chose the 2.5 GHz option and went to the GF setup. It only took maybe three seconds and I was rocking and rolling.
Then I went to my iPad to do a print.
Everything is perfect!! Thank you support for being very patient with me.
