I thought that there was a point in which, you could choose a proofgrade wood, and then adjust some settings from there. So if you wanted it to adjust speed or power, you had the ability to… now I don’t see them. Am I missing them? Did that change?
Choose Proofgrade automatic settings then select manual settings. The PG settings will populate the fields and you can change them.
/headdesk/
I KNEW it was there…
I’m glad you resolved it! I’m going to close this thread - if an issue reoccurs, go ahead and post a new topic. Thanks for checking in!
