Choose a Proofgrade setting, then click on Manual. The values for the Proofgrade are populated in the slots, and you can make slight adjustments with the sliders.
Sweet. Thatās the guidance I needed.
When theyāre not cutting through I drop the speed between 5 and 10 units. Thatās generally enough.
I was responding to the Glowforge staff member. The slight reduction in speed I mentioned had worked, proving that the lines of the file were just fine as well.
The first piece was not warped, it was stored flat with several other pieces and had no tilty edges. In fact, the second print with the reduced speed was on a piece of warped proofgrade (Itās warping was my own fault, it was a scrap piece left overhanging a shelf). It does prove your point, reducing speed can overcome warping. But my mention of it had more to do with the file being good.
Thanks @lizabeta. Iām sorry the default settings didnāt work well for you. Since you found a way to print successfully, Iām going to close this thread. I will pass on all the feedback about the settings.
