I have searched community and haven’t found any resolution. If I missed it, apologies in advance.
I purchased a multi use design file for coasters. In the description it said you could add additional layers to stack more than four. I was testing with different material and wanted to only print one coaster and ‘rim’ so I deleted the other files. I closed the file assuming that the main file would be saved and I could come back to it later.
I go back to look at the file and I have nothing. Admittedly, I am not fully versed on the GF design tool so it may have been me. I thought I read in an earlier post that once you closed your file, your setting and adjustments would not be saved.
Any advice on how to retrieve the master design file?
