I might not go as far as “ridiculous”. As soon as I read that, I pictured a laser engraved fireplace mantel engraved onto 1/4" stock laminated onto something thicker.
oh absolutely, there are plenty of uses for it. I just don’t actually need to do it.
But I’m gonna do it, anyway.
ETA: Great, now I want to make a mantelpiece. It’d be neat to do something like this, but with 1/4" wooden planks.
mmm… only ridiculous if you don’t have a table saw
I don’t (I should really fix that) but I can totally rip planks on the ol’ radial arm saw. I’ve never actually tried to do something that thin, though.
You rip planks with a radial arm saw? You are a daredevil sir. Just had to rip a walnut board yesterday for some drawer fronts (on the table saw) and ended up with a nice piece of leftover veneer… yes I kept it for the Glowforge.
I like to live dangerously… or negligently, I suppose. I don’t do much woodworking (which is probably obvious by my lack of a basic woodworking tool like a table saw) so I very rarely need to rip anything. The only time I’ve done it recently is when we were adding some under-deck waterproofing and needed to turn 30 feet of 2x4s into 60 feet of 2x2s.
eeps! To each their own, but that sounds scary to me…
you can get a used table saw for real cheap on craigslist, but they are bulky and require space to use and store.
If you have a hand-held circular saw you might be able to make a jig for long thin rips. I have a Kreg jig for my cordless that might be inspiration to start with. Mine is “not recommended” for widths under 1".
You could also build a table-saw using a hand-held circular saw:
Simple:
Fancier:
I’ve had building one on my project list for a while, but it’s a very long list and I am not moving through it very quickly.
haha, I hear that!
I use my handheld circular saw to rip a couple times a year, not as easy as a nice table saw, but when that’s all you have you learn to make due
I disagree. I will be lasering out measuring marks on door molding to mark off the kid’s height.
Fair enough. I don’t have kids, though, and at 6’4" the piece I’d need to laser to mark my own height can fit in the basic model.
that would be resawing(hard to do with a 1/4 inch thinkness, or a whole bunch of passes through a planer
I’ve done ripping with a table saw, a circ (including a homebuilt zero-clearance sled) and a bandsaw. OK, tried it with a saber saw once too… Unless you’re ripping something that’s not very wide, you’re going to need to plane it to final thickness anyway…
But the one thing I think many of us are missing (including me much of the time) is that laser cutters are mind-bogglingly precise compared to most of our other tools. So if you adjust for the kerf you can stack multiple pieces and have them come out to your final measurement.
I don’t suppose you have pictures of that laying around?
Ok, so I have a use case: Chain-link fence privacy inserts.
These could be up to 9’ tall, about an inch and a half wide (not sure about this, will check when I get home), and must be fairly thin. So ripping down 2x4s would probably work (one would have to calculate the time involved to see if it saved $$ over just buying thinner stock to start with. but saving money isn’t always everyone’s goal) Using the passthrough, and a sliced-up photograph/design one could engrave an image that stretched the length of the fence, or wrapped around an entire yard, or even around an entire playing field!
Lattice board might work, but it’s typically kinda spendy. And you can rip 2x4 really thin (I have made offcuts that are almost translucent). It might be worth investing in a thin-kerf blade, though, because otherwise you’re making as much sawdust as you are boards.
Random thought: instead of lasering the slats (which would be very nice but perhaps too subtle), use the laser to make a set of detailed stencils? You could then apply paint in whatever colors you chose – possibly with multiple stencil layers – and get some really cool results.
Oh, and the sled wasn’t much – just a piece of one-side-smooth 1/4" masonite with holes drilled to match the tapped holes on the bed of the circ, and measured for a specific offset. It rode against a smooth-ripped edge of some hardwood or other. If I’d been doing it right, I would have glued on some hardwood blocks with threaded inserts to set things up for an adjustable side piece faced with umhw tape – have I mentioned how much I love that stuff.
IMO a radial arm saw is very versatile, crosscut, ripping, molding, planning, sanding and even drilling with the PTO.
Killed the saw years ago, but if I were to buy another, it would probably be a radial arm.
Awesome awesome awesome idea!
