- How long have you had your GF?
- How many issues have you had (major) (can you tell me what they where)
- how many times have you sent your GF back to the mothership?
3a) and for what reason
Jonathan
Jonathan
Ordered during crowd sourcing and got our Pro machine Dec 2017.
No major issues. No repairs or replaced parts. Never have sent it back in.
Received November 2017. That is all I will say.
Nothing new under the sun:
Ordered during crowd sourcing and received Dec 2018. Had to replace the black lid cable once but have had no other problems. I have never had to do a camera calibration either as it is dead accurate.
• How long have you had your GF?
4 years, exactly…tomorrow
• How many issues have you had (major) (can you tell me what they where)
No major issues at all. Semi-minor only about 3 weeks ago…needed to replace the black lid cable.
• How many times have you sent your GF back to the mothership?
Never
and for what reason - n/a
Pre-order.
1st was DOA
2nd died at the depot. the FedEx guy went…oh, the one that sounds like glass? you don’t want that one.
3rd turned around mid-west.
4th has been just fine with all original parts.
Preordered in September 2015. Two pre-release units in early 2017. I received my production unit in August 2017. Warranty replacement with refurb exactly one day before the warranty expired.
I ordered late in Aug, 2017 received Feb 2, 2018, had many issues that I now trace almost all to not realizing about Magnets. Warranty Replacement after Christmas 2018, Was a mixup that I sent Pro but got back Basic so Pro arrived Feb 2, 2019.
Since then, only one black ribbon of death and one mysterious crash.
Of some note the difficulties of running then and now are amazingly easier and more accurate now,
Pre-release in '17 my own after that and no problems to date. Heavy use initially but that has tapered in the last year. The learning experience and the fun I have had easily makes it one of the best purchases I ever made.
I received one of the first production machines (vs a beta machine) 4 yrs ago and went through three of them pretty quickly, but at least one issue (probably two) were pretty basic things that had an easy fix, but the feeling I had was GF wanted to see the machine first hand to study what the problem was. (One was a loose camera housing, and I think one was basically a dirty fan or something along those lines.) I’ve had my current machine maybe 3 yrs-ish, and I won’t comment about the lack of issues because I don’t want to jinx it. I didn’t mind going through the other machines because GF would immediately send out a replacement without waiting for the return and it was pretty seamless, and they were pretty generous in compensating me for the hassle.
If you’re curious about reliability etc, something to keep in mind is us folks from 2017 will cause a bit of a distorted look at current reliability because the odds of the first few hundred machines being faulty is obviously much more likely than it is now, and I don’t know how comparable the stats would be.
Had a pre-release from Feb to Nov 2017. Worked as advertised until the company said I couldn’t keep it. Got my production Pro in early Nov 2017. No problems, no power degradation, no temperature issues, no stuck in calibration, no camera issues, no air assist warnings, no bumps, no lid warnings. Lost connectivity once during a blizzard. Coincidentally my internet went down for 12 hours at that exact same time. Weird.
Since Feb 2018
Five:
**2 1/2 years
About a year into use I needed to order and replace the black lid cable.
Never, and I hope I never do, as my machine was exported to Mexico and would be a hassle to get it back through customs.
I have had my machine for a little over 3.5 years.
I had an issue where support had to make a remote adjustment for a software issue and, an issue after cleaning the air assist fan (basically, the belt stretched out a bit). My machine consistently needs higher power settings to cut through even PG material but, it is predictable.
The machine has not yet needed to be shipped back for anything.
PRU in early 17, we had to repair the focus head on it then no other problems. Forever Pro unit September 17, no repair but I’ve had to run full calibration and I’ve lost the ability to read QR codes at some point. Both are what I consider minor but wanted full disclosure.
Mine’s one of the first Pro units off the line (four years now?) and it’s never had a problem that I didn’t cause. (Displaced the high power cable accidentally while cleaning it once, and spent a couple of nail-biting weeks with it down while Support worked out the best way to fix it. It never had to be sent back.)
Still on the original lid cable too.
I was sort of priding myself on running on all original components myself…but, any new record for that wasn’t meant to be since I did finally have to replace mine a few weeks ago. Gosh darned good run though…and today marks the day exactly four years ago when Glowria darkened my doorway and lit up my life.
You might still hold the record…I think you had your machine before I did, so it’s not quite four years yet for me. Still a couple of months to go.
