Hi all,
I have a piece of galvanized metal and I spent the week removing most of the layer of rust proof zinc so I could give it a weathered look. Used some Enduramark on the metal and it came out great. Some of the text is difficult to read because it is on a part of the metal sheet where the protective coating was removed. (The metal has a nice rusting coming through).
Can I spray something on it that will:
- Now inhibit the rust process?
- Make the text a little more legible?
I’ll try to post a picture later, I can’t take one with this computer and I don’t have my phone.
Thanks in advance.
Hit it with a little water mist. That’s likely how it’d look if you coated it with clear acrylic, which is what I’d use to coat it.
Don’t mist it with water as @randy.cohen suggested if you DON’T want any more rust.
Without pics, hard to say what would help the legibility, but you should be able to find a clear shellac or laquer spray that will adhere to metal (e.g. Rustoleum sprays) that should seal the surface and minimize the chance of any new corrosion.
Metal doesn’t rust that quick. At least, not that you can see. Mist it with water, dry it off once you’ve had a look. It won’t look any more rusted than it did before you misted it with water. If you left it wet for a week it’d start to show signs of additional corrosion. Assuming it’s galvanized steel, that is. If it’s something else, YMMV. But no matter what it is made from, a few minutes of water isn’t going to do much of anything. It probably spent years in the weather to get to where it is now. a few minutes of being wet is a fraction of a percent of the age of the metal. And getting it wet is the only way to judge how it will look when you coat it, short of actually coating it.
