Question with file making
I purchased a file for a “badge buddy” I want to make for work. There is a blank one that I want to add OB/GYN to it at the bottom opening. I thought I knew how to do this in Inkscape using union but it isn’t working. I need to combine my text with the file. Can anyone help? Hope I am making sense.
You first need to convert the text to a path. Then place the text on the path of the opening. Select both paths and select union.
I did that and it isn’t working. I must be doing something wrong.
So what does it look like? What part doesn’t work?
Make sure no parts are grouped as this will prevent a “union”.
