Not sure what it is?
See all the individual points/nodes? Thatâs the vector image. Is it possible that you deleted the Bitmap copy instead?
This might help, or might notâŚitâs a couple of quickie tutorials on rasters and vectors, and how the Glowforge uses them.
MehâŚyou might not need the second one.
Since youâre engraving thereâs really no reason to go through all these steps in Inkscape, especially as the process is causing you these open path errors.
Just send a JPG or PNG to the GF.
Definitely this, if you arenât adding a cut line to the image anywhere.
Iâm sorry that youâve been getting unexpected results in your prints. Itâs great to see that youâve already received some excellent information from our other community members. Thanks folks!
What they shared about the unexpected lines possible resulting from certain vector objects in the design is correct. In case it helps, we have a detailed guide on our support site which shows how to Rasterize Objects in Inkscape including screenshots of the process. Please let us know if this solves the issue with unexpected lines!
