Ive been attempting to engrave some more runs of some stuff for my shop, and I am unable to engrave in the quality I have been up until this point. Changing the LPI does not help. Ive uploaded a fresh 600dpi file, and still it is returning poor quality engraves. It appears that it is engraving at a much lower resolution than the file that I uploaded.
Did something change on the backend to cause this, and if so when can it be rectified?
Thanks!
Left side: failed engraves - right side: benchmark
Hmmmm… I wonder if that’s what ruined my 5 hour job today. Thinner wisps of curls in Edwardian Script didn’t engrave at all, leaving some little gaps in the letters. An arbitrary lowering of resolution definitely could have caused that. I was using 500/52/340 into cheap A.C.Moore wood. Should have been perfect in this case (as it has been in the past).
It’s not a physical machine problem. This is definitely a software issue. I just got a brand new pro 2 weeks ago, so it’s not dirt induced. I’ve made 4-5 of these engravings already, but today it seems that they no longer come out at the quality they were before.
I got mine 2 week ago too, and had to clean it for the third time today. Actually had a cut not go all the way through because it was dirty. Only reason I even thought of it.
Me. I was thinking on Friday I should clean everything. I didn’t, and my 5th or so project I was working on today used 2 full sheets of maple ply packed full of cuts and engraves. First sheet was no problem, but by the last 1/4 of the second sheet, it wasn’t cutting all the way through. Quick clean and all was good.
