Can you calibrate on something besides draft board?
Yes. It is just very important that it lays flat - tap on the surface, there should be no space anywhere between the material and the bed.
The instructions say:
It may work with other materials that are the same size and use the same print settings as well
thank you!
It should also be light in color. You can stick masking on it if it isn’t.
