Hi everyone! I’m looking for some help! I replaced the belt under the laser and have adjusted the tension numerous times but I still can’t get a clean engrave. When it prints it it is off and doubles the letters. If it is too tight the laser head won’t move. Has anyone experienced this?
Can you share a photo of your engraves? I assume you have read this: https://support.glowforge.com/hc/en-us/articles/4401913883547-Print-is-Distorted
Yes I went through everything about two times
I don’t think it is possible to make the belt too tight because you are limited by how far the pulley will move. The only time I have heard of the head not moving is when the belt is on backwards or twisted. Can you open the front door and take a photo of your belt? Have you double checked also for broken or cracked wheels?
I see you emailed us as well and we’ve just reached out there, so I’m going to close this post.
