Hi Glowforge Community! I’ve been lurking, learning and admiring up until now, but a technical problem has drawn me out of hiding.
The Proofgrade settings for Thick Draftboard is doing 3 passes and completely charring the edges of the cut. This is especially strange since the material is clearly cut through fully after the first pass. So it seems there’s a bug/error here. Has anyone else run into this? What can I do about it?
In an attempt to remedy the problem, I tried to do a custom cut with only 1 pass, but GF still did multiple passes. I don’t know if it would have done 3 passes again on my custom settings, because I shut off the machine as soon as it started to do the un-needed second pass.
Here’s a sceenshot of my custom settings that somehow had GF doing multiple cut passes:
Help! What’s going on?
