Revert "adjustments" for new speeds?
In the ‘Your Glowforge is getting faster’ post, Dan commented that “Your saved settings may be adjusted by about 5% to compensate for the changes.”
Is there an easy way to revert that? This has mangled the settings in my test/calibration files. And it didn’t just do that, almost my entire engrave speed test (110 swatches) has been set to 545/70, which is apparently SD engrave.
I’m working my way through unscrewing this file, but is there a way to revert to the settings in the file before you “fixed” them?
(as an aside, the new firmware has a bug where moves slow down as the cut speeds slow down. My cut test makes cuts at speeds from 500 down to 100, and the move between each cut gets slower as the cut speeds slow down)
You’re going to need to reach out to actual Support - we’re just owners here. They’ve got phone/Discord/email - click on “Support” up at the top and it’ll take you to their contact page.
