Not recommended to change out this wheel
So I repaired a worn wheel , and I managed to get the new wheel in place with the aluminum plate behind it , however it will not spin freely .
when I go to tighten it up to keep the belt tight it wont spin at all.
I am at a loss.
I have tried both sides of the wheel make no difference.
Anyone have any ideas is there a washer that I am missing ??
I did not see anything on the one I replaced.
They are the exact same wheel .
There is a washer that site between the wheel and the carriage! I would take the wheel off again, make sure the washer is there, then retighten it to the carriage and see if it spins without the belt on.
No sooner did i say that , a low and behold i found that Micro Washer , I thought I had watched carefully to see if there was a washer but it was on top of the Bolt .
Thank you So much,
For those that try this , Remember that washer goes on the top of the new wheel and not the bottom ,
Thank you
Coal
This is covered in the instructions if you follow them. They even have a detailed pic showing the washer.
