Was trying to position some cut elements around in the Glowforge UI and noticed that the gray “no cut” zone was changing size when I rotated a part?
In the two attached images you can clearly see the right hand keep out zone doubles in size when I rotate the part 180 deg without making any other changes. This seems like just a UI glitch but it makes it difficult to fully utilize the material.
