This has just begun to happen. Once uploaded, I can scale a job, but the rotation handle is missing. This makes it impossible to to effectively use material by rotating projects to fit between previous cuts.
If you’re trying to rotate bitmaps, you can’t. Only vectors can be rotated at that time in the UI.
I just modified a file I previously cut. I’ll look to make sure I didn’t do something weird. I’ll also try with a previously cut file that hasn’t been modified.
Thanks for the advice.
Jeff
Indeed, I did have a bitmap inside the SVG file. All is well. Thanks again!
Yay! Thanks @jbmanning5
