Does anybody happen to know if Rustoleum brand lacquer is laser safe? I have a request to engrave something extra onto a piece I already engraved and finished with the lacquer. Thank you in advance!
I have used it, but you have to make sure it’s dry. I let my pieces dry for a couple of days before I cut them out.
Ok thank you. I sprayed them like a week ago so should be good. Thank you again.
I also have used the Enamel in the same beand and in the Krylon brand. Never had a problem as long as it was completely dry. Usually 2-3 days is enough.
