Attempted to use GF this morning but it has been stuck in “Scanning…”. Laser head does not move, clicking noises when power on, and fan noise starts. The day before, I was able to successfully print a number of jobs without any connection/“Scanning” issues.
GF is connected via MiFi through a 2.4GHz/guest connection. Please help.
I extracted the logs from your Glowforge to investigate your report, and it looks like you’ve been able to print successfully since starting this thread. That’s great to see. If you were using a network device that was affected by a service provider outage, it may have caused calibration trouble. Could you please let me know if you’re still running into any problems with this? Thanks!
Thank you for the update and, miraculously, I was able to continue printing. However, the issue has happened again. I am waiting it out to see if it wants to finally start working…
@vee is there any explanation as to why the GF takes so long to power up? Like before, I turn it on and it stays in “Scanning”. I don’t know what I did to make it work two days ago but it seems that it randomly decided to start working. My guest Mifi shows that a device is connected so there doesn’t seem to be any connection issues. It just doesn’t want to stop “Scanning”. No movement at all from the printer.
Oh no! I’m so sorry to hear the problem has returned.
The issues you’re seeing might be caused by a poor connection with the cables on your lid. Please follow the steps below to check the lid connections:
Turn off your unit.
Open the lid.
Using both hands, gently roll the laser arm to the front of the unit.
There are 5 clips pictured below. Check each one to ensure it is closed. The clip should lie flat, and you shouldn’t be able to flip it in any direction.
If any of the clips are open, ensure the cable is inserted straight into the clip and close the clip.
If any of the cables are misaligned in the clip, take a photo of the clip and cable and send it to me so I can take a look before you proceed. Do not try to adjust or reseat the cable.
Close the lid.
Turn your unit back on and wait for it to calibrate.
Thank you for checking the clips and for the photos.
Unfortunately, it looks like your Glowforge is experiencing an issue that we can’t resolve remotely. I want you to have a reliable unit, so I’m recommending we replace this one. I’ll reach out to the owner of the Glowforge via email to sort out the details. I’m so sorry about the bad news.
