I am having trouble. I scored on GF proofgrade material acrylic medium 1/8, then I cut on 1/8 material at the same setting and the cut was not the same size of the score. What am I doing wrong?
Could you explain a bit more about the cut not being the same size as the score? The cut and score operation are the same process for the laser, but with different settings. The cut is supposed to go through the entirety of the material while the score marks the material at various depths but doesn’t cut through the material. Scores can be very shallow and barely mark the material, or deep enough to nearly cut the material.
Maybe you could share a photo to illustrate the different sizes.
Yes, we’d love to help you if you provide more info!
