Can anyone advise on the settings for engraving a glossy matte material like the box in the picture? I can’t determine a good comp or if it is worth the try. Thanks!
Hard telling from the picture. Where did you source it? Does it have a name? It could be a coated paper, and might be ok. It could be coated vinyl and not good at all to put in a laser.
Before you ask about settings, you need to get the material composition down.
Take some time to read this document on materials settings. it will give you a ballpark.
The link to the box site is below:
https://www.usbox.com/Mobile/Boxes/Matte-Magnetic-Gift-Boxes/1LV/
I did check the spreadsheet and still was a little stumped just because I did not see the specific name the website list.
Paper should be good to go. One way to test without wasting too much material is do a portion of the design with the fastest speed and 270 lpi with 5% power. See how it works. Then you can repeat with higher power as needed. Unless you are doing a raster engrave with a gradient. Then that is a total different kettle of fish.
Look for chipboard settings for engraving.
Thank you!
