I am glad you like it! Let me know if you have any questions when putting it together. Welcome to the community and Merry Christmas!
Made a set of these in August and yesterday had Christmas lunch with the friend they were forâshe is a reindeer fanaticâand she adores them! Thank you again for sharing these files!
You are welcome! Iâm so glad she liked them!
These are beautiful, I love the holder, but I currently only have thick acrylic, so rather than try to figure out how to resize everything, I created a simple baseplate out of the same acrylic, one of my first projects with the GF, and the baseplate is the first thing I created from scratch.
That is a great workaround! Love those!
Hereâs my version of this. The each layer has part of a Christmas tree (tree, lights, ornaments, outline), with six of them laid out in a radial pattern.
Thanks for the design!
That looks amazing!!! Great job!
wow. Love that design!
Just finished thisâŚit turned out great! Thank You
Do you mind me asking what size you made the coasters? Thanks
The base is for 3"x3" coasters.
Edit: wait! Youâre probably suffering from the same thing as me⌠The original coaster set is sized for 3.75". However, export size between Illustrator and importing in Inkscape does not match, not by a long shot. Since I designed this, I have switched to a new Inkscape version and set my defaults differently too. So depending on what you open the file in, the sizing can be different. I know @designvh619 , ended up converting a lot of his files to pdf - which ensures correct handling regardless of what program.
bravo pour la realisation c tres bien reussi !!
Merci beaucoup!!
Thank you for sharing this idea! I am brand new to Glowforge and just learning Inkscape. I think this is more of an Inkscape question. On the right, you see that I have clipped part of the picture out to fit on my coaster. Yet, when I load the file into GF, it shows the stuff that was âclippedâ out. Any suggestions? I have been playing with it for awhile, and I am sure someone on here knows. I think I was expecting clip to work like crop, and it is not! I also tried it as a PDF with the same result.
I am excited to print my design using your coaster idea.
I am not really an inkscape guy. But if the cut line is inside of the engraved area it doesnât matter that it engraves something that will get cut away. Unless you want it to be exact.
The doesnât recognize masks, you have to actually change the shape or itâll run the full engrave.
You can either actually cut the image - or make a bitmap from the clipped one (itâs in the command lines, but I donât know whereâŚ)
This should help: Adobe Illustrator to Inkscape: clipping paths and masks
âŚduh! SighâŚthank you for an obvious answer!
thank you!
It used to be if you used a clipping path the GFUI threw out lots of whiny messages about not supporting clip paths. Now it does something else, but I donât use clip paths so I donât pay much attention. Iâve only had to deal with them in files made by someone else.
No real help I know, but thatâs the history.
Do you still have the file for the Star Wars Coasters
