Sharing project designs
How can I share a project with another glow forge owner?
You could post the design in this category and that would give it to everyone here. Or you can contact them directly through their profile.
If you’re asking if they can access something on your dashboard, the only way would be for you to give them your login info - which you shouldn’t do. You also have the option of creating a new user for sharing, and uploading it there, then they can login to that user on their machine and see what you uploaded.
Welcome to the forum.
Welcome @rich.pireaux to the forum.
If you design something and wish to share it with others this would be the correct place.
It is always better if you share context for your inspiration, your design criteria, photos of the building process, and of course the design file with the order and type of operations (score, engrave or cut) with the settings used, as this enriches and inspires our community members.
If what you want to share is with just one other community member, then you can export your design from the GF interface and just email him the .svg file, or from the design software you used in .pdf, .svg or adobe illustrator format.
This topic was automatically closed after 2 days. New replies are no longer allowed.
