I use my GF nearly on a daily basis, cutting fabric at short bursts of 1-2 min jobs. So, this is pretty familiar to me as a set up already.
Today, when I loaded up my blank and pressed ‘print’ the head went from it’s resting position at the top LEFT of the cutting area and moved down to the bottom RIGHT and made a little creaking/fluttering noise. I’ve heard this before and it usually means it’s going outside the cutting area and the 0x0y is now off. I cut my first blank and sure enough, the pattern is shifted over to the left about .25".
I don’t know if this is GF admin trying new things to get a bigger cutting space, but I am un able to cut anything because I use the exact maximum cutting area and cannot afford to move it over .25" that it’s now re-calibrating at every time.
Tried resetting, the machine 3-4x and reloaded the GF interface as well as close my browser and reopen.
Soooooo what is it?
