I have limited space in my shop like many of you. A while back I made this stand for my shipping station. My scale goes on top and my Rollo label printer and labels are directly underneath the scale. I can weigh a package and print the label and it takes up a small amount of counter space. The back is open for loading a stack of labels. The large cutout in the side allows for turning the printer on and off. I slide the printer out the front to load labels and then put it back in place.
I decided to share this file in case it would be of use to anyone else in the group. It was made from 1/4" PureBond from Home Depot. You may need to adjust slots for your material. It is designed to fit the Rollo printer so if you have a different unit you may need to adjust sizes to fit. The scale was from Amazon. (I don’t remember which one exactly but there are several to choose from.) I will be mounting the scale readout to the wall behind the unit but I just haven’t done it yet. Don’t mind my terrible job on staining this. I tried a new stain that I really ended up not liking. Luckily no one sees this but me.
Zip file contains three svg files. Top, Bottom, Sides.
ShippingStation.zip (6.7 KB)
