My side belt tension on the left side is loose. I checked and the back “wheel” is tight (used a 3mm hex key to be sure) so I believe this belt needs to be replaced.
The right one is in great shape. How do I go about getting a replacement? Or where can I buy one?
The belts aren’t available OTC at this moment (they’d be at shop.glowforge.com if they were), but by posting here you’ve contact Support and they can work with you to fix the one you have, or send you a replacement. Now that it’s Monday you should hear back soon.
I can see that you’ve also reached out via email and that our support team has contacted you there. To avoid duplicate communication and expedite your process, I’m going to go ahead and close this topic.
